How to apply TTS license
We ordered two ports realspeaker license. How can I apply it? Thanks.
Re: How to apply TTS license
Are you talking about how to apply the licnese or how to enable TTS?
I am asking apply the license. I know once the license is applied, it's very simple to enable TTS.
Gold
There's an 'Upgrade License' tool in the Unity program group that will apply your new license file. In order to actually have the RealSpeak engine if you previously had the L&H 3000 engine, you will need to reinstall Unity. This isn't as bad as it sounds, you just rerun the setup process and you don't lose any data (but obviously read over the documentation and take a backup first).
We don't have L&H 3000 engine. Do we still have to reintstall unity?
Never mind. I found the information I need. Anyway, it also has to rerun the setup.
111
