How to block an incoming call
I have a person receiving unwanted calls from an outside party. Is there a way to block this activity? We are using Cisco CallManager 4.1 and my PRI trunks come in through Cisco 2811 gateways.
Re: How to block an incoming call
No, there is no way to block a "calling" number in CallManager you can only block a "dialed" number.this is because you can only
modify the called number and NOT the calling number
In addition, CCM can not do this but it can be done ONLY using H.323 Gateway. Take a look to this URL:
http://www.ciscotaccc.com/voice/showcase?case=K15182736
As it was suggested by the previous answer, you could block incoming calls on the H.323 gateway. However it impossible if your IOS gateway is configured with MGCP.
What I could suggest - enable "iDivert" button for this user. At least he will be able to drop the call to the VoiceMail without answering the phone.
Also you could contact your phone service provider and ask them to block this inbound number - some of them can do this.
Good luck,
Michael Shavrov
http://www.ciscoheadsetadapter.com
I think you can do it by createing a new route pattern for this spicific number and forwored it to some of your gatways that could not handel the number.
Thank you & Best Regards,
Umar Al-Juhani
You could create a translation patteren for this number and have it forwarded to the security station or any number you choose.
Pete
190
