Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
how to block incoming call
We use AS5300 for VoIP with ISDN signalling.
We want to block incoming call (call from PSTN to AS5300) and allow outgoing call (call from AS5300 to PSTN).
What should we add in our configuration?
Here is our config:
controller E1 1
pri-group timeslots 1-31
controller E1 2
interface Serial1:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice modem
isdn T310 60000
no cdp enable
interface Serial2:15
no ip address
isdn T310 60000
no cdp enable
voice-port 1:D
cptone ID
voice-port 2:D
cptone ID
dial-peer voice 10 voip
destination-pattern T
session target ras
dial-peer voice 3 pots
destination-pattern 007T
direct-inward-dial
port 1:D
dial-peer voice 4 pots
direct-inward-dial
port 2:D
1 REPLY
Anonymous
N/A
Re: how to block incoming call
nothing to add, just take out the dial-peer voip, so no incoming calls will be routed and 5300
will fail any incoming calls.
208
