Community Member
how to configure DID using VG200 as MGCP gateway?
I have a Callmanager 3.1(3a), VG200 12.2(2)XN. I configured the VG200 in Callmanager with T1 PRI interface. I also configured VG200 to use CCM for single point configuration. However, I could not find where to configure DID since I am not supposed to configure num-exp in the VG200?
1 REPLY
Re: how to configure DID using VG200 as MGCP gateway?
If you are using vg200 with MGCP then you really don't need to configure DID. They are multilple ways to accomplish this. For example if you are using 4 digit extensions and the telco was sending 4 digits you don't have to do anything. If your DID range was 1000-1099. Then configure an ip phone with 1000. When you dial xxx-xxx-1000 from the pstn your phone will ring. If the telco is sending 7 digits an you are uinsg 4 digits extensions you can just set num digits to 4 and make sure sig digits is checked or you can use a translation pattern to accomplish the same thing.
I hope this helps,
-Mckee
98
