The MFT card that must have been refrenced abd VWIC
which are voice Wan interface crads and can either be used
with voice products or used in wan slot as a WIC.
For voice support you need an HDVM module (high desity voice module) which
you put in line of the network module slot and you can then use the vwic in the slots
in voice mode.
Connecting to the PBX would require voice port created and also DSP which
will do the voice compression & packetisation.
You must buy an HDV module for voice support with Vwics.
