Community Member
How to configure sending DTMF codes for a long distance provider via ISDN?
Hello!
I've cisco 3825. I want to configure sending DTMF codes after call setup to long distance provider.
I solve this in fxo by dial-peer configuration:
dial-peer voice 107 pots
trunkgroup common
permission term
description From Common - test
huntstop
destination-pattern 11005318751
prefix 11005318751,,,,,,,,,,42641980255
But this configuration doesn't work for isdn.
I think only tcl can solve my problem. I'm right?
1 REPLY
Re: How to configure sending DTMF codes for a long distance prov
ISDN doesn't use DTMF for call setup which is why the configuration you have used for POTS doesn't work. The gateway collects all digits and send it out in a H.225 setup message, rather than playing it out over the voice channel.
As for how to do that... There maybe an option using a custom made TCL script/application, but it would definitely be a solution that was outside the box. I'm afraid I don't know TCL well enough be help you out there.
331
