how to connect to a extension number?
Does anybody knows how to connect to the extension number using tapi, for example, if I need to dail 416-5555555 ext.111, after I connected to 416-5555555, what tapi methods should I use in order to connect to extension 111?
kevin
Re: how to connect to a extension number?
Download the TAPI API manual from the Developer Services webite at www.cisco.com/go/developersupport . This will walk you through the supported methods, and events. Be aware though, that using TAPI 3.0 is unsupported, and you may find trouble developing to 3.0.
Once stations are connected you should use "lineblindtransfer" to transfer it to ext. that you want.
Agam
What if I need to dial the extension number one by one? Lets say extension number "155", I need to dial 1, then 5, then 5, Which method should I use then? linedial? and what else?
kevin
116
