Community Member
how to connect two PBX isdn D channels through routers transparently?
PBXa-------routerA---------------WAN---------------------routerB---------PBXb
e1 e1
pbxa and pbxb want to exchanges D channel information
transparent ccs?but the WAN leased line is DDN
Re: how to connect two PBX isdn D channels through routers trans
if your pbxs are capable of using qsig then use qsig between the pbx and router at each end, then setup dial peers and it should all work.
if the pbx cannot use qsig but can use dpnss then you can use a dpnss/qsig convertor (we use the iiq2000 from westell) these can be setup in transparent mode and forward all dpnss functionality. again setup dial peers on your router
hope this helps
Community Member
PArt of what you want to do is nail up the d-channel signalling between the two PBX's. Then the key is that the PBX's need to be the same manufacturer for this to work. Different manufacturers, then Q.SIG is where you need to go and your capabilities will be deminished.
Silver
If all you want to do is pass the D channel information without needing to switch the audio , you can use a channelised E1 and configure timeslot 16 for STUN encapsulation. The D channel is tunnelled in the STUN, which then uses TCP/IP to route to the destination. The D channel signalling frames will be sent across the network and will pop out in TS 16 at the far side.
If you need to pass voice traffic as well, you will need to configure connection trunk on each timeslot to nail down each DS) to a corresponding timeslot at the remote site.
130
