How To Define Dial Plan in ART 1.1(1)SPc
Does any expert know how to define the dial plan under ART 1.1(1)?
I just wants to sort out the dial out number that have at least 10 digits or more.
I sort out the report with the following steps:
Device report>gateway>details>gateway type or dial pattern
The access code for dial out to PSTN is 9.
I tried define the dial plan with the following methods, it doesn't work.
Condition No. of digits Pattern Call type
> 10 9! other
I select the call type other in my report.
The report list the dial out records that include 3 digits, 5 digits and >10 digits
Together, the file size of the report only have 283KB, if the records are very large, it will not be listed. I need run the report per day.
How can I increase this limitation ? or increase the file size of the report by the ART system.
Thanks in advance!!
1 REPLY
Silver
Re: How To Define Dial Plan in ART 1.1(1)SPc
Not much has been documented on cisco.com about the dial plan in ART . May be the following documents should help you.
ART Logic: How Calls are Classified
http://www.cisco.com/warp/public/788/AVVID/artlogic_5300.html
Configuring ART
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/admin/admin_rp/1_1_1/user_gd/artch2.htm
230
