06-06-2002 06:11 AM - edited 03-12-2019 07:07 PM
I am able to receive Caller ID from my office, but it is the number for my E1 line. However, I would wish to have Caller ID display for all my internal lines. How do I enable that?
06-06-2002 06:14 AM
If you are just talking about calling from one IP phone to another you should not have to do anything to get number. Are you talking about name or number caller id?
Thank you,
-Mckee
06-06-2002 06:47 AM
Hi Mckee,
I am refering to name or number caller ID to be displayed on outsider phone, etc. I am using a Cat 4006 with voice gateway WS-X4604-VGWY, CCM ver 3.1.
At present only one number is displayed for all outgoing call.
Paul
06-06-2002 08:21 AM
Hi Paul,
I didn't quite understand what is the problem but if you want to force diferent number (like direct number so outside person can call) to appear outside you have 2 ways:
- on the route pattern use "Use Calling Partys External Phone Number Mask" and on the phone line define the number or mask(wildcards) that you want to appear.
- on the route pattern use "Calling Party Transform Mask " where you can use 1 number or wildcards. Ex: extension range 1100 to 1199. To appear diferente number on the outside use a mask like 2121333xx, where xx will be the last 2 digits of the extension.
I hope this help.
Sergio
06-06-2002 09:06 AM
First thing you should do is to contact Telco to make sure the CO switch supports that. Sometimes they can only send the billing number or the main pri number..
hope this helps
Marina
06-06-2002 09:59 AM
Thanks for the help, Telco confirm that all my numbers support caller ID. I am trying the transformation, hope to see some results..... I will keep the group update, any further info will be helpful.
06-06-2002 10:35 AM
In order to have each and every phone display their assigned DIDs on the caller ID, youhave to configure the line settings for each line.
Go to the phone settings, select the desired extension, and at the bottum of the page you'll see the options for line settings.
Display, is for internal use. Type the user name and the last name where the
External Phone Number Mask is the DID that will show on caller ID.
If you have four didgit extensions type : 212422XXXX.
The first six digits will be displayed as typed where the XXXX will be replaced by the assined extension on that line.
Good Luck,
Afrim Sapun
06-17-2002 02:36 AM
Hi everyone,
I can't get this caller ID display works, what are the steps to get this thing done? Can any other CCM/voice gateway setting offset what everyone has taught me to do?
append is my voice gate config:
logging buffered 4096 debugging
aaa new-model
aaa authentication password-prompt PASSWORD(Authorized-User-Only):
aaa authentication username-prompt USERNAME(Authorized-User-Only):
aaa authentication login default local
clock timezone SGP 8
ip subnet-zero
no ip source-route
ip audit notify log
ip audit po max-events 100
isdn switch-type primary-net5
no call rsvp-sync
no voice hunt unassigned-number
no voice hunt invalid-number
voice service voip
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g711alaw
voicecard mode gateway
controller E1 1/0
pri-group timeslots 1-31
description : : First E1 line to PSTN
controller E1 1/1
description : : Second E1 Line to PSTN
translation-rule 68275
Rule 0 ^682756.% 6
Rule 1 ^682757.% 7
Rule 2 ^682758.% 8
interface Loopback0
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.1.1
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0.5
interface GigabitEthernet0/0
no ip address
no negotiation auto
interface GigabitEthernet0/0.1
description : : Virtual Routing Interface for Voice VLAN
encapsulation dot1Q 50
ip address 10.178.196.252 255.255.255.0
ip helper-address 10.178.223.11
interface GigabitEthernet0/0.2
description : : Virtual Routing Interface for User VLAN
encapsulation dot1Q 4
ip address 10.178.192.252 255.255.255.0
interface GigabitEthernet0/0.4
encapsulation dot1Q 1 native
interface GigabitEthernet0/0.5
description : : Virtual Routing Interface for ETPL VLAN
encapsulation dot1Q 3
ip address 10.178.204.252 255.255.255.0
ip helper-address 10.178.204.4
interface GigabitEthernet0/0.10
description : : Virtual Routing Interface for Server VLAN
encapsulation dot1Q 2
ip address 10.178.223.250 255.255.255.0
interface Serial1/0:15
description : : First E1 line D-Channel to PSTN
no ip address
no logging event link-status
isdn incoming-voice voice
isdn T309-enable
isdn send-alerting
isdn sending-complete
no cdp enable
interface Serial1/1:15
description : : Second E1 line D-Channel to PSTN
no ip address
isdn T309-enable
isdn send-alerting
no cdp enable
ip default-gateway 10.178.223.1
ip http server
ip http access-class 80
ip classless
ip route 0.0.0.0 0.0.0.0 10.178.223.1
ip route 10.178.203.0 255.255.255.0 10.178.223.251
ip pim bidir-enable
logging trap debugging
voice-port 1/0:15
input gain 1
output attenuation 1
echo-cancel coverage 24
cptone SG
voice-port 1/1:15
input gain 1
cptone SG
dial-peer voice 10 voip
incoming called-number 68275...
destination-pattern 68275...
progress_ind setup enable 3
translate-outgoing called 68275
session target ipv4:10.178.196.1
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
ip precedence 5
no vad
dial-peer voice 100 pots
preference 1
destination-pattern ........
progress_ind alert enable 8
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 101 pots
preference 1
destination-pattern 9........
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 102 pots
preference 1
destination-pattern 1800T
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 103 pots
preference 1
destination-pattern 6.......
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 104 pots
preference 1
destination-pattern 1...
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 105 pots
preference 1
destination-pattern 800T
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 106 pots
preference 1
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 200 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 201 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 202 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 203 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 204 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 205 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
dial-peer voice 206 pots
preference 2
direct-inward-dial
port 1/1:15
forward-digits all
voicecard sccp manager 10.178.196.1 port 2000
voicecard sccp local Loopback0
voicecard conference
voicecard transcode
end
