How to extend PBX to remote office
I have 4 users that need access to the corporate PBX system. The users are located in a remote office that is connected to corporate via a point-to-point T1. I would like to setup 4 handsets at the remote office that connect to the corp PBX. It seems like the cheapest way I see of doing this is to use two 1751 routers with 4 voice ports each. This is still rather expensive. Are there other alternatives? If I use Cisco IP phones how would I connect them to the PBX? If I use the IOS routers where can I find a sample config for a setup such as this?
Diego
1 REPLY
Re: How to extend PBX to remote office
Diego,
If you were to use IP phones you would need to connect something like a 6608 router to your PBX via a T1. Then you would need to set up a route pattern in CM to access the PBX. Hope this helps
124
