noc
How to limit possible e164-id from netmeeting voice terminal?
I have h323 gatekeeper (2600), gateway (3640) and several voice terminals
(PC with NetMeeting). I need in terminal authentication and use h323id
authentication on gatekeeper side. But user on netmeeting with right
h323id/password can set any phone number in options, and gatekeeper
doesn't check this e164-ids, it use it. How can i restrict use only one
e164-id from one h323id device? Also next thing - as i use h323id
authentication on gatekeeper side, i have to use h323id on 3640 gateway in
form h323id:password (i set separator symbol as : on gatekeeper side), and
during calls from POTS to voice terminal voice terminal user can see all
gateway information with password too. This is not right. How can i
resolve it?
Thank you very much!
Anonymous
N/A
Re: How to limit possible e164-id from netmeeting voice terminal
noc
Thank you! I just setup h.235 authentication between gatekeeper and gateway with use crypto tokens, and this is what i am need. But NetMeeting doesn't support it. Do you know any h323 voice terminal software with such authentication support? Cisco IP SoftPhone need in CallManager, but i have only gatekeeper, and looks like it doesn't support h.235 authentication too. For Linux i found GnomeMeeting with h.235 support, but i need in software for Windows. Also may be Cisco have plans to implement some authorization on gatekeeper side for limit e164 numbers for voice terminals?
90
