You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
How to prioritize voice traffic using c2621 and cisco IP telephones or other IP gateways through Frame Relay?
2621 is connected to Frame Relay and want to prioritize voice traffic going from Ethernet0/0 (other data traffic goes also via Ethernet 0/0)(using IP telephones or other IP gateways, which supports IP precedence)
Which type of queuing should we use (and how- the example would be the best) and what parameters should be set for FR links ?
  • Other Collaboration Voice and Video Subjects
Anonymous
N/A
Re: How to prioritize voice traffic using c2621 and cisco IP tel
IP precedence is really unecessary if you are
doing voip over frame-relay. The queuing mechanism would
be Ip rtp priority which create two queues. A high
queue for voip traffic and a low queue populated by the queue
mechanism used for data traffic. In the example below it is
WFQ.
Also to ensure good voice quality, large data packets
should be fragmented to reduce the propagation time across the link. The
frame relay tc should be kept at a small value to reduce
the maximum time we will need to wait for a token ( i.e. clocking of next frame on the wire)
Example below shown how these issues are addressed.
Interface ethernet 0
ip address 2.2.2.1 255.255.255.0
int ser 0/0
encap frame-relay
frame-relay traffic-shaping
no ip address
interface serial0/0.1 point-to-point
ip add 1.1.1.1 255.255.255.252
frame-relay interface-dlci 100
class voice
map-class frame-relay voice
frame cir 64000
frame bc 640
frame mincir 64000
frame-relay ip rtp priority 16384 16383 48
frame fragment 80
frame fair-queue 64 256
You don't want to use wieghted fair queueing becase voice priority will be non existent when the link becomes congested.
You can use low lantency queueing to mark and provide a low latency queue for high priority traffic over frame-relay.
On the LAN side it is important to provide a queueing mechanism in your core and access switches so that voice traffic is queued out LAN interfaces to your 2600 first.
There are 2 portions
RTP or constant voice traffic and Call control traffic wich does call setup and tear down. usually RTP is set up with an IP Precedence of 5 and Call Control has a precedence of 3. Only 8k of bandwidth is needed for call control traffic for hundreds of phones but depending on how many phones you have you can limit the priority or bandwidth in the policy.
frame-relay cir 512000
frame-relay mincir 512000
service-policy output QOS-Policy
int serial0
Frame-relay traffic-shaping
int serial0/0.100
frame-relay class voice
class-map VoIP-RTP
match access-group 102
class-map VoIP-Control
match access-group 101
policy-map QOS-Policy
class VoIP-RTP
priority percent 100
class VoIP-Control
bandwidth 8
class class-default
fair-queue
access-list 102 permit udp any any range 16384 32767
access-list 102 permit ip any any precedence 5
access-list 102 permit ip any any dscp ef
access-list 101 permit tcp any any range 2000 2002
access-list 101 permit tcp any any eq 1720
access-list 101 permit tcp any any range 11000 11999
access-list 101 permit udp any any eq 2427
______________________________
This puts ip precedence 5 and 3 in different queues on my switch.
For my 6500
#qos
set qos enable
set qos map 2q2t tx 2 1 cos 3
set qos map 1p2q2t tx 2 1 cos 3
set qos wred 1p2q2t tx queue 1 40:80 70:100
set qos wred 1p2q2t tx queue 2 40:80 70:100
set qos cos-dscp-map 0 8 16 26 32 46 48 56
set qos ipprec-dscp-map 0 8 16 26 32 46 48 56
This sort of question is answered by attending the Cisco Deploying Quality of Service course ;)
It is a very good course actually.
664
