How to record call handler greetings?
We want to pre record call handler greetings on a PC.
Copy the greetings to the Unity server.
Then use the paste from file option to build the call handlers.
We recorded the greetings with XP Pro using Sound recorder.
When we attempt to paste fron file we get a message from Media Master "Unable to paste the audio".
Is there a reccomended procedure for recording the WAV files?
Re: How to record call handler greetings?
Which codec did you use to record the greeting in XP Pro? I suspect it's a codec not on the box... the media master will do it's best to convert if it can but if the codec isn't installed it'll fail and you'll get a message like that.
We converted the files to CCITT u-law.
Now it works great.
173
