How we can Conf ATA186 to receive Call from PSTN via VOIPGW 5300
Kindly suggest how we can config ATA 186 such that a PSTN Call Landing at VOIP GW AS5300 can be forwarded to ATA 186 in the same VOIP Network. We can config Voip-dial-peer at VOIP GW but spl. config required to be done on ATA 186(similar to dial-peer POTS, may be using UserID or LoginID field????).
Would appreciate your kind reply.
Shailendra
Re: How we can Conf ATA186 to receive Call from PSTN via VOIPGW
Take a look at the page below. There is a section on Cisco ATA.
http://www.cisco.com/warp/public/788/voip/voip.shtml
Hope this helps,
-Mckee
You basically have to decide on both AS5300 and o9n the ATA186, which Voip Protocol are you going to use.
Once you determine that,
• Under the VoIP dial-peer on the AS5300 you set the following things:
• Destination-pattern
• Codec
• Session target
• Session protocol
Thanks. I assume we need to just configure uid0 & uid1, Gateway IP, ATA IP/Mask/Static GW(defualt GW) and matching RX/TX/LBRCodec on ATA to allow Inbound & Outbound H.323 based Calls.
Shailendra
115
