HP Teaming issue on MCS7835
Hi there,
I have 5 CallManagers all with teamed network interfaces, all showing the following error in the event log:
Event Type: Error
Event Source: CPQTeamMP
Event Category: None
Event ID: 338
Date: 10/30/2005
Time: 4:05:14 PM
User: N/A
Computer: ES911
Description:
TEAM0: PROBLEM: An attempt was made to add a team member to a team. The new team member failed attempts to determine its Link State and/or Link Speed. The attempt to join the team has been failed. ACTION: Disable and (re-)enable this team's Network Connection on "Network (and Dial-up) Connections" page.
HP Website states this is a know bug and resolution is to upgrade the NCU to version 8.10 and the drivers for the network cards to 8.10.
Because of the locked down nature of the OS, if I upgrade these to get rid of the issue, will the servers still be supported Cisco? Does anyone have experience or advice on Cisco's policey of updating drivers on MCS's using vendor updates?
Cheers,
Mike Graham
Super Bronze
Re: HP Teaming issue on MCS7835
What version of the OS from Cisco are you running (i.e. 2.???)...?
Perhaps the newer version of the OS image or upgrade will have the updated drivers which will be a better option than upgrading individual components?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Only the best for these boxes, 2000.2.7sr8.
Any other thoughts?
Also CCM is running 4.1(3)sr1 with ES20 applied.
Super Bronze
Nothing terribly constructive :-)
Is it actually causing any issues?
With the error reporting inability to determine speed/duplex... what config have you on your ports? Are they 100Full or Auto?
Aaron
112
