Hunt list/pilot problem - urgent!
I have the following strange problem with a hunt/pilot setup.
1- Created a line group existing of 3 DN's
2- Created a hunt list which includes the above line group
3- Created a hunt pilot which routes calls to above hunt list
The problem I am experiencing:
When I call the pilot number, the call arrives at the first DN defined in the line group. After 3-4 rings on that DN I receive a busy signal(!). A top-down approach was configured.
Why does the call not arrive on the 2nd DN in line if a no-answer state is received on the first DN.
I resetted all phones, hunt list and even rebooted the CCM's, running 4.1.3SR(2).
Thanks for giving any direction!
Peter
Re: Hunt list/pilot problem - urgent!
Peter, have you tried to change the order of the 3 DNs?
If you have the Line group:
1000
1001
1002
Try changing the order e.g:
1001
1002
1000
Now does it ring the first phone?
If it does not, then this phone is probably not reachable or not configured properly.
Veera
Have you configured the following under the _Hunt Options_ of the Line group
No Answer
Busy
Not Avavilable
these fields should all be set to:
Try next member, but do not go to next group
(unless you have another Line Group, like maybe voicemail)
HTH,
Rob
Can it be the timers in the Line-group and the Hunt-pilot , if this timers as the same value, it will stop hunting !!
143
