Hunt pilot outside call problem
I have setup a Line group/Hunt list/hunt pilot. the ext number is 8855 consisting 4 extension numbers.
when i call 8855, the 4 members in the group can answer in a circular way. for the call from inside, that's no problem at all.
the problem is, when i use my mobile to call the full number, 3842 8855, one guy's mobile rings. that's not what i want. i want it the same way as internal call - one of 4 guys' desk phone ring.
this guy is one of the 4 members and i am 100% sure he never forwards his desk phone call to his mobile.
can anyone help me with this? many many thanks.
btw, i am using CM8.0
  • Other Collaboration Voice and Video Subjects
Everyone's tags (2)
Even if they forwarded their phone to their mobiles you would never ring their mobile if calling via a hunt pilot.
Most likely you have something else in your dial plan that's doing that, that's the 1st thing you need to check.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
i have checked i don't have any dial plan at all.
are you using SNR for this 4 number in the line group??
thanks,
Vipul Jindal
No i didn't configure Single Number Reach on any of these 4 extensions.
can you please upload the call manaeger traces for one of the call?
thanks,
Vipul Jindal
sorry for being away for quite a while.
For tracing, 8855 is not a normal extension, it is a hunt pilot. in trace config, it can trace call to phones, CTI route point, gateway etc. but it can't trace a call to hunt pilot and in Phone-directory number, i can't find 8855.
I also asked my phone line servive provider. they ask me the full number 3842 8855 is a DDI on PABX or just a extension which has a CFWD on it? they can't find this number thus they don't have diversion for this number at the exchange level.
any idea?
thanks.
need call maanger to analyze!!
thanks,
Vipul Jindal
What's the exact call flow of the call and what protocol are you using at the GW??
java
java
625
