Hunt Pilot / Pickup Group
cyoungblut
I have a scenario that is giving me a problem with pickup groups and I need some assistance. I have 3 extensions (1410, 1411 & 1412) that are part of a pickup group. That pickup group works fine. However, we have an after hours line group with a hunt pilot of 1420 that rings phones 1410 & 1600(broadcast). When a call goes to 1420 it rings 1410 & 1600 just fine but users at 1411 & 1412 cannot pick up the call ringing on 1410. Says call is not available. Is there a different way to set that up so it can pick up that line? I thought maybe adding 1420 to the pickup group but that does not appear to be an option. We are running CM 5.1.
Rob Huffman
Hi Chris,
Here is a link to the actual Tac Case Collection for this fix. No patching or reboots should be required :)
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K11612191
Hope this helps!
Rob
18 Replies 18
Rob Huffman
Hi Chris,
Hope all is well with you! You are on the right track with adding 1420 to the Pickup Group,but you are hitting this bug CSCsb12946 which prevents this feature from working (still applicable in 5.1);
Set enterprise parameter (System->Enterprise Parameters->Cisco Support Use 1) Cisco Support Use 1 to CSCsb42763 (case sensitive)
This operation added listbox (Route Plan->Route/Hunt->Hunt Pilot->hunt pilot XXXX -> Call Pickup Group) Call Pickup Group.
From this doc;
1.- Enter
CSCsb42763 (in mixed case) in the Enterprise Parameter 'Cisco Support
Use 1' under the new group 'Cisco Support use Only' and click update. Only the value
CSCsb42763 in this parameter can enable the configuration. Change the
value to anything else to disable this functionality.
2. Go to Hunt Pilot Configuration page and select a call pickup group from the Call
Pickup Group dropdown list and click update.
CSCsb42763
Call Pickup fails on Hunt List
Issue:
Call pickup fails for hunt list when call is CFA from Route Point in 4.1(2)ES41. This is not the designed functionality for this issue and will break the Call Pickup logic.
Workaround:
Use multiple shared lines & CFNA between each shared line.
Related Bugs
Call Pickup fails when ringing line list member
Symptom: Selecting PickUp or GPickUp does not pickup the call from any of the members of a line group. Condition: CM 4.x Workaround: None. Feature not supported. Further Problem Description: Defect CSCsa66224 may appear to have allowed this feature to work in earlier versions.
Call Pickup from line group member fails after es installed
Symptom: A call is CFNA to a hunt pilot/line group. The call can no longer be picked up. Conditions: Calls CFNA to a hunt pilot. 4.1(2)ES36. Workaround: None
Hope this helps!
Rob
Great answer by Rob, not that I've understood much, still my rating - a 5!
Hey Paolo,
Welcome back, and thanks for your continued kind support :)
Here is the "skinny"
This ability to add Hunt Pilot #'s to Pickup groups used to work and people got really used to it. Cisco decided that it wasn't supposed to work in the first place so they went out and broke it :( After much complaining by the masses, Cisco relented and grudgingly came up with this setting (that allowed this to work again);
I'm not sure why they didn't just fix it ??
Take care my friend,
Huff
Just to be clear on this... by entering CSCsb42763 in this field and saving it this will give me the option to add a call pickup group to my hunt pilot number???? (Is there a patch/fix to download and put on Callmanager first?)
Also, do I need to reset and if so will it interrupt phone operation? Sorry - just want to be absolutely clear before making any changes.
Thanks again for all your help.
There is also one other 'feature' to be aware of when doing this. If you want to delete the pickup group, you need go first set the hunt pilot to use a different (or no) pickup group BEFORE trying to delete it from Feature --> Call Pickup Group
Failure to do this then means you cannot then access the hunt pilot screen and the work around for this is to delete the Hunt Pilot in SQL (there is a Cisco doc for this)
Rob..thanks for this..I was pulling my brains out trying to figure out why the call pickup wouldnt work with the hunt pilot..I followed your instructions and VOILA!! it worked..thanks again...5 points for you!!!
Thank you so very much for this! I have been struggling with this same subject for some time now, but this worked fine!
t.Satu
Rob Huffman
Hi Chris,
Hope this helps!
Rob
Thanks again Rob - that did the trick!
-Chris
Rob Huffman
Hi Chris,
You are most welcome my friend :)
Happy Holidays!
Rob
Just for everybody's information.
The same problem still exists in CUCM 6.0 and 6.1 and can be cured by the same method shown above.
Good luck everybody! :)
Hi Alexander,
Thanks for posting up your results :) 5 points for sharing this info for others to share!
Take care,
Rob
Guys,
Is this setting supposed to be available in CallManager 4.0 sr2? I can't find the Cisco Support entry under the Enterprise Parameters.
Bad CallManager!
Hi Bruce,
This setting is first available in 4.0(2a)SR2 :(
Sorry man!
Rob
