I am trying to figure out how to make/ensure there is ANI/Caller ID on outg
I am trying to figure out how to make/ensure there is ANI/Caller ID on outgoing POTS dial-peers. This has been a frustrating challenge…
I have T1 E&M connections to both a voicemail (Octel) and PBX using both a 3660 and 2651 gateway.
I simply want to know two things, how can I tell that ANI is being sent and what it is.
Here is an example configuration:
cas2600#show ver
IOS (tm) C2600 Software (C2600-JS-M), Version 12.2(liszt_dev1.0.1.0), CISCO DEVELOPMENT TEST VERSION
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Mon 11-Feb-02 16:07 by shawnk
Image text-base: 0x80008088, data-base: 0x81A17AFC
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
cas2600 uptime is 7 weeks, 1 day, 19 hours, 18 minutes
System restarted at 19:00:32 GMT Wed May 22 2002
System image file is "flash:c2600-js-mz-liszt_dev1.0.1.0.bin"
cisco 2651 (MPC860P) processor (revision 0x200) with 59392K/6144K bytes of memory.
Processor board ID JAB05410H6K (2064170137)
M860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
2 Channelized T1/PRI port(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
cas2600#show run
Building configuration...
Current configuration : 6504 bytes
! Last configuration change at 09:15:13 GMT Fri Jul 12 2002
! NVRAM config last updated at 16:45:33 GMT Wed Jun 26 2002
version 12.2
no parser cache
service timestamps debug uptime
service timestamps log uptime
hostname cas2600
boot system flash c2600-js-mz-liszt_dev1.0.1.0.bin
no logging buffered
logging console emergencies
enable secret 5 --moderator edit--
enable password gw2600
clock timezone GMT -8
voice-card 1
ip subnet-zero
ip ftp username root
ip ftp password password
ip domain-name sylantrolab.com
ip name-server 172.16.x.x
isdn switch-type primary-5ess
voice service voip
h323
voice class codec 1
codec preference 1 g711ulaw
no voice hpi capture buffer
no voice hpi capture destination
fax interface-type fax-mail
mta receive maximum-recipients 0
controller T1 1/0
framing sf
clock source internal
linecode ami
ds0-group 0 timeslots 1-22 type e&m-wink-start
ds0-group 1 timeslots 23-24 type e&m-wink-start
description Octel VM
controller T1 1/1
framing esf
linecode b8zs
cablelength short 133
ds0-group 0 timeslots 1-24 type e&m-wink-start
description Chatterbox
translation-rule 1
Rule 1 null null
interface Tunnel1
no ip address
interface FastEthernet0/0
ip address 172.16.x.x 255..255.255.0
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface Dialer100
no ip address
no ip mroute-cache
no cdp enable
ip default-gateway 172.16.x.x
ip classless
ip route profile
no ip http server
ip pim bidir-enable
no cdp run
call rsvp-sync
voice-port 1/0:0
output attenuation 3
echo-cancel coverage 32
timing clear-wait 1000
timing wink-duration 250
timing hookflash-in 600
station-id name Octel VM
station-id number xxxxxxxxxx
voice-port 1/0:1
station-id name MWI
voice-port 1/1:0
station-id name chatterbox
mgcp ip qos dscp cs5 media
mgcp ip qos dscp cs3 signaling
no mgcp timer receive-rtcp
mgcp profile default
dial-peer cor custom
dial-peer voice 5000 voip
preference 1
application castransfer
incoming called-number 5[1-4].%
destination-pattern [2-9]......T
progress_ind setup enable 3
voice-class codec 1
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
dial-peer voice 5010 voip
description MWI CAS
preference 1
destination-pattern *9[4-5]....
voice-class codec 1
session target ipv4:172.16.x.x
dtmf-relay rtp-nte
no vad
dial-peer voice 5020 voip
description cas to pri call
preference 1
destination-pattern 1..........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1010 pots
preference 2
application session
destination-pattern xxxx
port 1/0:0
dial-peer voice 1020 pots
preference 2
application session
destination-pattern xxxxxx
port 1/0:0
dial-peer voice 1030 pots
preference 2
application session
destination-pattern xxxxxxxxxx
port 1/0:0
dial-peer voice 1040 pots
description CAS VM integration
preference 2
destination-pattern 51.%
no digit-strip
port 1/0:0
dial-peer voice 1050 pots
preference 2
destination-pattern 52....
no digit-strip
port 1/0:0
dial-peer voice 1060 pots
preference 2
destination-pattern 53....
no digit-strip
port 1/0:0
dial-peer voice 1070 pots
preference 2
destination-pattern 54....
no digit-strip
port 1/0:0
dial-peer voice 1080 pots
preference 2
application session
port 1/1:0
dial-peer voice 1090 pots
preference 2
application session
port 1/1:0
dial-peer voice 2000 pots
preference 2
application session
port 1/1:0
gateway
sip-ua
max-forwards 2
retry invite 7
retry response 7
retry bye 7
retry cancel 7
timers trying 1000
timers expires 300000
timers connect 1000
timers disconnect 1000
no oli
sip-server ipv4:172.16.x.x
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
exec-timeout 0 0
password --moderator edit--
login
no scheduler allocate
ntp clock-period 17180508
ntp server 172.16.x.x
end
Re: I am trying to figure out how to make/ensure there is ANI/Ca
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
E&M Wink does not support Caller-ID. E&M Feature Group D does, but that's basically like ISDN PRI and usually costs as much if not more that PRI.
Thanks. I worked out that I have to configure the 2600 trunks and E&M-FGD. Unfortunately, the gateway does not provide dial-tone when configured as E&M-FGD.
227
