I have a PBX connected to a Cisco 2621 with a HDVM and a vwic. This has a DPNSS - QSIG converter and voice calls all work fine. Can anyone explain to me what happens at the gateway and how H 323 converts the DPNSS signal to give full DPNSS functionality a
I have a PBX connected to a Cisco 2621 with a HDVM and a vwic. This has a DPNSS - QSIG converter and voice calls all work fine. Can anyone explain to me what happens at the gateway and how H 323 converts the DPNSS signal to give full DPNSS functionality across the link (Laser link) because I was not expecting full functionality and only limited H 323 functionality similar to H 323.
1 REPLY
Anonymous
N/A
Re: I have a PBX connected to a Cisco 2621 with a HDVM and a vwi
DPNSSis a proprietary pBX signalling nto supported on cisco
device as yet so it can be terminated on the box.
If your using a converter to Qsig, then we can guarantee
a voice signalling and some supplementary signalling on qsig but not all.
the voice port is configured for qsig nto dpnss and it terminates the qsig
signals at the port and generates a new h225(q931) signalling over the voip cloud.
This is then terminated to the receiving end and re-initiate qsig out it port to the converter which
then converts the q-sig to DPNss.
NO you cannot achieve full dpnss functiionality over the h225 cloud. The only way to do this
is to trunk between the two PBX or do
a TDM cross connect, so that the router does not terminates the call nor know what protocol is being transmitted in
the ds0 cross connected or trunked.
130
