I have some problem with IP to IP gateway
I briefly describe my scenario. I have a voice gateway in which are linked some IP phones. Then this router is connected to a SIP proxy that forward the calls to an IP to IP Gateway wich converte the SIP in H323 protocol to transport voice to internet.
Now when I try to call an softphone on my PC from an IP phone behind the voice gateway I don't heard anything and the call goes down.
Seeing the SIP debug I noticed that the IP to IP gateway is not able to create a rtp link because it doesn't know the ip address of Voice gateway.
Do I have to configure anything?
Thanks.
Paolo
Re: I have some problem with IP to IP gateway
Can you paste your IPIPGw config ?
Green
Ciao Paolo!
Verify that you have setup your incoming dial-peer SIP and outgoing Dial-peer H323.
MAke sure theres no codec missmatch or if using different XCODER is available. (Configure SRST or CCME in the IPIP GW itself)
This guide may help you.
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_guide_chapter09186a00806b09eb.html
Let us know
//G
132
