I need help with 831 DMVPN QOS config
I am looking for a QOS method that allows the best voice quality with little delay and, with the exception of EIGRP updates, I don't care about other traffic. In addition, I would like to use the same QOS config for every 831. I don't want to modify it for each cable/DSL uplink speed. Any suggestions?
The reason is we are having voice quality issues using 831's for a pilot project work from home solution. I knew that voice packets destined for the 831 were delayed when someone at the remote site was downloading a large file but otherwise the quality was pretty good.
More recently, the quality is degrading and it's not just a delay anymore. It appears I have a problem with the QOS method. In the past, the local Cisco office has told me what the Cisco recommended QOS method was. Yesterday I was told that our 831 DMVPN/IP Phone SOHO solution had to do shaping. If I do that, then I will have to modify each config for the uplink bandwidth which I don't want to do.
Currently I am using a config derived from a MQOS PDF found on CCO but I'm not sure it's doing the job. Does anyone have a suggestion on how to make it better?
class-map match-any VOICE-CONTROL
match dscp af31
match precedence 3
match ip dscp ef
match ip precedence 5
policy-map IPTVPNQOS
class VOICE
priority 64
class VOICE-CONTROL
bandwidth 10
class class-default
fair-queue
interface Ethernet1
service-policy output IPTVPNQOS
Output from one of the remote 831's. It looks like the queuing is working since there are no dropped packets but maybe I'm reading it wrong?
831# sh policy-map interface e1
Ethernet1
Service-policy output: IPTVPNQOS
Class-map: VOICE (match-any)
2303960 packets, 370616992 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: ip dscp ef
2303963 packets, 370617158 bytes
5 minute rate 0 bps
Match: ip precedence 5
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 64 (kbps) Burst 1600 (Bytes)
(pkts matched/bytes matched) 8365/1386290
(total drops/bytes drops) 0/0
Class-map: VOICE-CONTROL (match-any)
87408 packets, 13072818 bytes
Match: dscp af31
5 minute rate 0 bps
Match: precedence 3
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Output Queue: Conversation 265
Bandwidth 10 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 1634/205710
(depth/total drops/no-buffer drops) 0/0/0
Class-map: class-default (match-any)
1854668 packets, 466305032 bytes
5 minute offered rate 2000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/0/0
1 REPLY
Anonymous
N/A
Re: I need help with 831 DMVPN QOS config
231
