IAD2400 capabilities
Hello.
I have some questions about the IAD2400 series:
1) Can it act as a Voice gateway by connecting 16 analog phones (using the 16 ports FXS) to an IP network, running VoIP, using the 10BaseT interface ? In other words - can i run VoIP over the Ethernet interface of the device ?
2) The same question as question-1 but using the serial port instead of the 10BaseT to connect to the VoIP network.
3) Does IAD2400 support multicasting: IGMP, PIM, etc ?
Thank you,
Boaz.
1 REPLY
Re: IAD2400 capabilities
answers:
1) yes, but the caveat is with the type of signaling it is capable of:
Q. Which call control protocols are supported by the Cisco IAD2420?
A. Cisco IAD2420 supports MGCP 0.1, MGCP 1.0, and SGCP 1.5.
Q. Does the Cisco IAD2420 support H.323 or SIP?
A. No. The current generation of IAD2420 products does not support H.323 and SIP.
Yes, voip will work onj the ethernet interface.
2)serial ports will work as well as long as you are using one of the signaling protocols described above.
3) Yes
290
