ICD question....need help
Referencing the eServices administration guide,I am trying to install ICD. In the instructions it refers to adding a user in call manager and adding the ICD agent extention to the ICD agent extension field (withing "adding a new user" in CCM.) Refer to 6-2 of the eServices administrator's guide.
Where the heck is this field? I do not see it anywhere when adding a new user....This is new stuff so if anyone out there can give me a hand...I would really appreciate it!
1 REPLY
Re: ICD question....need help
The field should have been added automagically to the Global Directory when you are editing a user. Since it obviously did not, try going to the Windows Services applet under Administrative tools, choose IIS Admin, and do a Restart. Say Yes when prompted.
When that is done, check again. If it's still not there, you will need to go into the DC Directory to update the field by hand that turns this field on, then restart IIS Admin again.
If you need help with this, please feel free to open a case with the Cisco TAC, but the field is in O=cisco.com/OU=CCN/OU=systemprofile/CN=System Profile and there is an attribute called "IAQ Flag" which should be set to "true". Or you can use your favorite command-line ldapmodify utility to do this.
123
