10-07-2003 02:27 AM - last edited on 03-25-2019 06:40 PM by ciscomoderator
Does anyone know if ICM version 5.0(SR1) or 5.0(SR2) is compatible with CCM version 3.3(3). The CCM compatibility matrix seems to indicate that ICM 5.0(SR1) is only compatible with CCM 3.3(2) however the page hasn't been updated since 7/7/03.
10-07-2003 01:13 PM
Cisco Golden Bridge Compatability Matrix current supported software matrix:
Contact Center Components
CallManager 3.3(2)SPC
ICM 4.6(2)HF117
CTIOS 4.7 Cisco
IP-IVR 3.0(3a)SPA
CAT6608 GW/Transponder FW Bundled CatOS 6.3(10)
CAT3660 (Gateway) 12.2(13)T3
10-13-2003 11:11 AM
Last Updated 9/12/03 - Cisco CallManager Compatibility Matrix
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/ccmcomp.htm
10-13-2003 11:55 AM
Just because the CM Compatability Matrix has been updated does not mean it gone through Cisco Golden Bridge testing. Cisco has an initiative called Golden Bridge that tests all IPT/CallCenter and release it's current supported versions. The post above is Cisco current Golden Bridge tested scenarios.
adignan - berbee
11-02-2003 09:14 PM
Can you post a link to the Golden Bridge matrix?
