ICS 2.5.0 Upgrade Issue/Question
Upgraded went fine except for the following:
MRP200 w/ FXO cards do not function correctly. Images uploaded fine to cards, but now call to not go through the gateways. These two MRP200 are config'd with MGCP.
Odd thing is that the third MRP200 works perfectly. Calls inbound and outbound go through - they do not get stuck at the gateway. The only differences in this MRP are that it has a T1 card and is cofig'd for H323.
On the two MRP200 that do not work after new image (12.2.8) applied, I just re-applied the previous image (12.2.4) and they are back to functioning. I would like to have the new image on all MRP's in the chasis.
One more thing - I noticed that when I went from 2.1.0 ICS ver to the new 2.5.0, it upgraded everything but CCM. CCM is still at 3.1.2c
Any help would be appreciated...
1 REPLY
Silver
Re: ICS 2.5.0 Upgrade Issue/Question
These links might help you troubleshoot the problem
Installing and Upgrading Cisco ICS 7750 System Software
http://www.cisco.com/univercd/cc/td/doc/product/voice/ics/ics25/icstg25/tsinst2.htm
Troubleshooting Cisco ICS 7750 Software
http://www.cisco.com/univercd/cc/td/doc/product/voice/ics/ics25/icstg25/tssoftw2.htm
Hope this helps.
89
