ICS-7750 and CCM 3.3(5)
Does anyone know if CCM 3.3(5) is supported on the ICS-7750?
In the release note for 3.3(5) the ICS is mentioned, but it never says that it really is supported.
I found a document dated in march this year saying that 3.3(4) and 4.0(2) is supported but I don't think that 3.3(5) was available back then. My customer is getting the error hardware not supported when she is trying to upgrade.
She is running 3.3(2) for the moment and wants to be able to run the Cisco2811 as a gateway.
Re: ICS-7750 and CCM 3.3(5)
3.3.5 is not supported on the ICS-7750. The document that you read is accurate even though it was march. The release notes for 3.3.5 are errored. Sorry to be the bearer of bad news.
Did she order CCM with part number that looks like SW-CCM-xxx-ICSxxx?
http://www.cisco.com/en/US/products/hw/voiceapp/ps967/prod_eol_notice09186a008032d553.html
I found internal documentation that CCM 3.3(5) is not supported on ICS. The internal bug id is CSCee55018.
93
