ICS 7750 and VG248
Does anyone have experience in both of these equipments working together ? any problem ? Thanks for any response.
Duc Vu
Re: ICS 7750 and VG248
You need to have had your ICS7750 already upgraded to 2.x software so that you can run CallManager 3.1(2c) or later on your SPE-310 blade(s). That is the minimum CallManager version required to support the VG248.
I've seen people use it successfully with the new ICS7750 version 2.1, since it supports later versions of callmanager. I don't know about the 1.X versions of the ICS7750.
83
