ICS 7750 Voice T1/PRI's per MRP
- The ICS 7750 guides make a statement that only 1 Voice T1/PRI is
supported per MRP (and of course appropriate DSP's).
The question is if I use a VWIC-2MFT, with the first port configured for
local service using say 8 channels, the second port used for LD service
with 12 channels, and the remainder of the second T1/PRI port for data,
is this supported - possible?
For the sake of argument, the local and LD service cannot be combined
onto a single circuit.
Or do I play it safe and get another MRP with a VWIC-1MFT and needed
DSP resources?
1 REPLY
Bronze
Re: ICS 7750 Voice T1/PRI's per MRP
I think it will configure and may even work but I don't think it's supported. Double check with a tac rep to be sure.
82
