ICS7750 and CM 4.0 upgrade
Does anyone know the part number for the CM upgrade for this system? The release notes say it is supported on the ICS - Is it really?
Re: ICS7750 and CM 4.0 upgrade
Hello:
Just as a side note......
I just upgraded a customer ICS7750 to CCM 3.3.3sr4. After the upgrade the system was a lot slower. I have to wonder if it is even going to be able to support CCM 4.02. Customer had SP310's with 512Meg. What version are you running now and how is the speed of Admin?
Carl
Our ICS system is running 3.3.3sr4 also. We have 2 SPE's with a gig of memory each. The system runs fine (no speed issues with ccmadmin). The release notes for CM 4.0 listed the ICS system as approved hardware. Who knows. We should have never bought this thing - First we buy it, then cisco says they need to replace all the hardware and completely rebuild the system. Then 3.3 comes out and you have to rebuild again - With the ICS you can't just pull one of the servers off line and rebuild it - everything is in production. It took me all night to get the install done.
89
