idle url removal
a.caja
When I put an url idle image on one ip Phone and someone call, the image go away when you hook -off the phone or press any key. You can´t see before how is calling.
How can I get the idle URL to go away when the phone rings?
Thanks.
r-simpson
Level 3
Level 3
I think you have to configure the Directories button to know
Missed Calls
Received Calls
Placed Calls
Corporate Directory
Also check the following URL
How do I make the Directories Button work?
http://www.cisco.com/warp/customer/788/AVVID/faq-ipphone.html#Q5
Hi, this is not my problem. I can see all those calls with the Directories button.
But my problem is that I want to see how is calling while I have an idle url image on the phone. I can hear the phone ringing, but I can´t see the phone which is calling me until I answer the call.
Thanks.
Try Using UP or Down Arrow before going off-hook
