Implementing a restriction for 2 calls
I have a centralized CM with 9 remote small offices. I am looking for only 2 simultaneus calls at each link. Does anybody knows how to do it?
Gerardo Hernandez
Re: Implementing a restriction for 2 calls
Use locations to limit the bandwidth to 2 calls. Just be sure that all phone in the remote site register to the same call manager.
Thank you,
If I limit the BW at each location for 2 calls (22 kbps for 2 calls using G.729), I will limit local calls too. I was thinking in a QoS policy at each router but I am not sure this is the right way.
Gerardo
By using locations you will only specify the bandwith between sites, not within sites. So if you want to limit the link to 2 calls you will need to specify 48Kbps for the remote locations. (By using a QoS policy at each router you won't be able to restrict the number of calls)
Bram
204
