Implemention QOS for Voice
We have a 2Mbps LL 1:4
we are using CSICO ATA for Voice.
we are using cisco 2620 router .
Here are my questions.
1.Kindly check My config and say whether this QOS config will work for prioritising the Voice.
class-map match-all VOIP-RTP
match ip dscp ef
policy-map VOICE-QOS
class VOIP-RTP
priority 1024
interface Serial0/0
description ### STPI-GATEWAY-VASHI ###
bandwidth 2048
ip address 213.11.12.115 255.255.255.252
ip access-group 103 in
ip access-group 103 out
service-policy output VOICE-QOS
shutdown
2.How can i filter the HTTP,TELNET,SSH,RDP,FTP traffic.
Kindly help me.
Ranga
Re: Implemention QOS for Voice
1. Assuming your device/switchports are trusting/setting your RTP to ef then the class-map is ok. Your policy-map is using half the bandwidth available. Cisco recommends only upwards to 33% allocated to the LLQ. This is a design recommendation. Do you plan to have that many calls? That is an estimated 12 or so G711 calls.
2. Can you explain whether you are looking to filter based on QoS or Security? Either way you can do this with ACLs. ACLs can be assigned to class-maps and you would match your traffic on IP or port. Of course ACLs can be used to filter the data traffic by assigning the ACL to the interface with the access-group command. NBAR and CBAC could be used for QOS/Security application aware filtering.
Please rate any helpful posts.
Fred
You also have to check what mappings your switch may have.
For example, some switches map IP Precidence 5 to DSCP 40. EF is 46. You would need to change your mapping to make IP Prec 5 map to DSCP 46.
A more scalable config (that you dont have to redo too much) might include bandwidth guarantees for other classes of traffic as well...
Also, I like to go with the qos design guide recommendation and set aside a queue for voice signalling... like the following...
i also dont "match ip dscp ef" but rather just look for rtp audio... dont always have a marking switch/phone system behind your router... sometimes its a whitebox phone system sending rtp packets, and a dumb switch... I also go with a nested policy, which shapes all to the speed of the link, then decides which traffic will follow the rules of the child policy to leave the single queue ;)
class-map match-any manage
match protocol dhcp
match protocol dns
match protocol kerberos
match protocol ldap
match protocol snmp
match protocol syslog
class-map match-any bulk
match protocol exchange
match protocol ftp
match protocol pop3
match protocol smtp
class-map match-any voicesignal
match protocol h323
match protocol rtcp
class-map match-any transactional
match protocol citrix
match protocol pcanywhere
match protocol secure-telnet
match protocol sqlnet
match protocol sqlserver
match protocol ssh
match protocol telnet
match protocol tsrvrdp
class-map match-any video
match protocol rtp video
match protocol cuseeme
match protocol netshow
match protocol rtsp
match protocol streamwork
match protocol vdolive
class-map match-any voicebearer
match protocol rtp audio
policy-map Pol-S0/0/0.1-child
class voicebearer
set dscp ef
priority percent 25
class transactional
bandwidth percent 25
class voicesignal
bandwidth percent 5
class manage
bandwidth percent 5
policy-map Pol-S0/0/0.1-parent
class class-default
shape average 1444000
service-policy Pol-0/0/0.1-child
int s0/0/0.1
service-policy output Pol-S0/0/0.1-parent
(yes not all my classes are used in my policy; they are for future use... nice to have them in there now though, as they can always be allocated some bandwidth later on, at the expense of what is carved out now...)
Tschuss,
Joe
106
