inbound audio delay
I have a 2620 mgcp gateway running 12.2.15T with config listed below. I am running CM ver 3.3. About 2-3 times a day the receptionist recieves an inbound call but there is approximately a 5 second delay before she can hear the caller. However the caller can hear the receptionist just fine right away. Any ideas?
clock timezone CDT -6
clock summer-time CDT recurring
voice-card 1
codec complexity high ecan-extended
ip subnet-zero
ip cef
no ip domain lookup
ip multicast-routing
isdn switch-type primary-ni
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice class codec 1
codec preference 1 g711ulaw
codec preference 14 g729r8
voice class h323 1
h225 timeout tcp establish 1
no voice hpi capture buffer
no voice hpi capture destination
ccm-manager switchback immediate
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
fax interface-type fax-mail
mta receive maximum-recipients 0
controller T1 1/0
framing esf
linecode b8zs
cablelength short 133
pri-group timeslots 1-12,24 service mgcp
class-map match-all VOIP-Contrl
match access-group name VOIP-Control
class-map match-all VOIP-Bearer
match access-group name VOIP-Bearer
class-map match-all Call-Control
match ip dscp af31
class-map match-all Voice
match ip dscp ef
policy-map VOIP-Policy
class VOIP-Bearer
set dscp ef
class VOIP-Contrl
set dscp af31
policy-map VOIP-Policy-T1
class Voice
priority percent 70
class Call-Control
bandwidth percent 5
class class-default
fair-queue
interface FastEthernet0/0
ip address X.X.X.X 255.255.255.0
ip pim dense-mode
service-policy input VOIP-Policy
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr X.X.X.X
interface Serial0/0
bandwidth 1536
ip address X.X.X.X 255.255.255.252
ip pim dense-mode
service-policy output VOIP-Policy-T1
service-module t1 timeslots 1-24
service-module t1 remote-alarm-enable
interface Serial1/0:23
no ip address
no logging event link-status
no snmp trap link-status
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no isdn incoming alerting add-PI
no cdp enable
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip pim bidir-enable
ip access-list extended VOIP-Bearer
permit udp any any range 16384 32767
ip access-list extended VOIP-Control
permit tcp any any range 2000 2002
permit tcp any any eq 1720
permit tcp any any range 11000 11999
permit tcp any any eq 2428
permit udp any any eq 2427
permit udp any any eq 1719
permit udp any any eq 5060
linkdown linkup coldstart warmstart
call rsvp-sync
call application alternate DEFAULT
voice-port 1/0:23
echo-cancel erl worst-case 3
echo-cancel suppressor 10
mgcp
mgcp call-agent X.X.X.X service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp package-capability rtp-package
no mgcp timer receive-rtcp
mgcp profile default
dial-peer cor custom
dial-peer voice 117 pots
tone ringback alert-no-PI
preference 1
application mgcp
incoming called-number .
destination-pattern 9
direct-inward-dial
port 1/0:23
call-manager-fallback
limit-dn 7940 1
limit-dn 7960 2
ip source-address X.X.X.X port 2000 strict-match
max-ephones 24
max-dn 48
alias 1 XXXXXXX to 3001
Silver
Re: inbound audio delay
We also had the same exact problem for a customer. It was intermittent throught the day. Changed to phone load cmterm-7940-7960.P003-3-3-4.exe which resolved the problem.
You can find that load from this page.
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-7900ser
--Partha
We are having the same issue. I have worked with Cisco a few times with no luck. Its hard to capture the debug information they are looking for when it only happens every so often. About a month ago this was a huge issue and after rebooting the CM it seemed to resolve all of the issues, but now it is starting to happen again. We are running CM 3.3(2) and phone load P00305000400. I am doing the latest patch and OS upgrades this weekend. Have you had any luck since posting?
I'm sure TAC has already covered this ground, but make sure you are running the same version of the attendant console on the client and the server. Mismatches can cause weird problems.
130
