Inbound Caller ID not passed through FXO / PLAR
Hello good people. I am working on an ITS rollout. I have four PSTN lines, each pluggin into an FXO port on my 2620. My FXO ports are configured to PLAR to ephone-dn numbers that are present on the phones that I would like to see and receive incoming calls. However, the incoming calls only show up as 'private' before answer and 'external call' unknown when aswered. Is there a way to beat this? Everything i see on the FXO ports seems to tell me that it should be on by default, but is there something I missed?
<snip>
voice-port 2/0
input gain 8
timeouts interdigit 3
timeouts call-disconnect 1
timeouts ringing 18
connection plar 1
<snip>
telephony-service
max-ephones 20
max-dn 20
ip source-address 10.1.1.1 port 2000
auto assign 1 to 20
timeouts interdigit 2
timeouts ringing 20
create cnf-files version-stamp 7960 Aug 15 2003 15:04:56
max-conferences 4
secondary-dialtone 9
Thanks everyone, and good luck to all!
Jerry Craven, CCNP
Allied Technology Group, llc
1 ACCEPTED SOLUTION
Bronze
Re: Inbound Caller ID not passed through FXO / PLAR
Caller ID is supported on the VIC-2FXO-M1.
It looks like you are missing the caller-id enable command under the voice port.
Jerry,
You should do a IOS Debug "debug voip ccapi inout". This will tell you whether you are getting the CLID from the carrier or not. Feel free to post it to the forum.
D
So if you are getting CLID from the carrier on an FXO port, this should pass through to the phone?
as far as i know CLID is not passing through analog phone lines. and cisco VIC-FXO doesn't support any CLID protocols.
Bronze
Hello all,
Sorry to have left this out there. Dugrant wins the award on this one, and don't think I didn't want to disqualify myself from VOIP networking when I realized I had left off such a simple command. I thought it was the default, but I was wrong.
I should note, however, the first time I called TAC an engineer told me to 'upgrade' my vic2-4FXO cards to the M versions which, by the way, are apparently close to the end of their life cycle. hmm.
Jerry
210
