Incoming and outgoing VOIP Dial peer
I have the following setup
A 1760 router (hostname=RL01) where the FastEthernet 0/0 port is connected to the CallManager Subnet and a WIC-1T serial interface is connected second 1760 router (hostname=RL02).
On RL02 I have connected an analog phone to a FXS port. What I'm trying to accomplish is to make a phone call from my analog phone across the point-to-point link to and IP phone. See dial peer's below:
RL01 Config
interface FastEthernet0/0
ip address 172.17.13.99 255.255.255.0 {CallManager Subnet}
interface Serial0/0
ip address 172.17.15.1 255.255.255.0 {P-2-P link to remote Lan}
encapsulation ppp
no fair-queue
dial-peer voice 98 voip {VOIP Peer To remote analog phone}
destination-pattern 7099
session target ipv4:172.17.15.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 97 voip {VOIP peer to CallManager}
destination-pattern 6000
session target ipv4:172.17.13.10
codec g711ulaw
no vad
RL02 Config
interface Serial0/0
ip address 172.17.15.2 255.255.255.0 {P-2-P link to remote Lan}
encapsulation ppp
clockrate 4000000
no fair-queue
dial-peer voice 1 pots {Analog Dial Peer}
port 2/0
forward-digits 4
dial-peer voice 99 voip {VOIP peer to Remote network}
destination-pattern .
session target ipv4:172.17.15.1
codec g711ulaw
no vad
As a test I tried moving the analog phone to RL01 and put the same dial peer on it and I could sucessfully make phone calls to and from the IP Phones. When I have the analog phone on the remote roter RL02 I get reorder tone.
Here is a "debug voip ccapi inout" output from making a call from Analog to IP phone
*Mar 1 23:38:32.678: cc_api_call_setup_ind:
*Mar 1 23:38:32.682: cisco-username=172.17.15.2
*Mar 1 23:38:32.682: ----- ccCallInfo IE subfields -----
*Mar 1 23:38:32.682: cisco-ani=7099
*Mar 1 23:38:32.682: cisco-anitype=0
*Mar 1 23:38:32.682: cisco-aniplan=0
*Mar 1 23:38:32.682: cisco-anipi=0
*Mar 1 23:38:32.682: cisco-anisi=0
*Mar 1 23:38:32.682: dest=6000
*Mar 1 23:38:32.682: cisco-desttype=0
*Mar 1 23:38:32.682: cisco-destplan=1
*Mar 1 23:38:32.682: cisco-rdn=
*Mar 1 23:38:32.682: cisco-rdntype=-1
*Mar 1 23:38:32.682: cisco-rdnplan=-1
*Mar 1 23:38:32.682: cisco-rdnpi=-1
*Mar 1 23:38:32.682: cisco-rdnsi=-1
*Mar 1 23:38:32.682: cisco-redirectreason=-1
*Mar 1 23:38:32.682: //-1/xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: (vdbPtr=0x8246B6A8, callInfo={called=6000,called_oct3=0x81,calling=7099,calling_oct3=0x80,calling_oct3a=0x0,calling_xlated=false,subscriber_type_str=Unknown,fdest=1,peer_tag=98, prog_ind=3,callingIE_present 1, src_route_label=, tgt_route_label= clid_transparent=0},callID=0x81DC7C5C)
*Mar 1 23:38:32.682: //-1/xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: type 0 , prot 1
*Mar 1 23:38:32.682: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
*Mar 1 23:38:32.682: ccCheckClipClir: calling number is: "7099", calling oct3a is: 0x0
*Mar 1 23:38:32.682: Calling Party number is User Provided
*Mar 1 23:38:32.682: Leaving ccCheckClipClir
calling oct3 is: 0x80
*Mar 1 23:38:32.686: //-1/xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: (vdbPtr=0x8246B6A8, callInfo={called=6000, calling=7099, fdest=1 peer_tag=98}, callID=0x81DC7C5C)
*Mar 1 23:38:32.686: //59/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: Increment call volume: 0
*Mar 1 23:38:32.686: //59/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: current call volume: 1
*Mar 1 23:38:32.686: //59/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: entry's incoming TRUE.
*Mar 1 23:38:32.686: //59/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: is_incoming is FALSE
*Mar 1 23:38:32.686: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructHashProfileTab: profileTable[0x81DC44B4], numBuckets[11], numEntries[0]
*Mar 1 23:38:32.686: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
*Mar 1 23:38:32.686: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x81DC44B4] with objects in container[0x81DC2E90]
*Mar 1 23:38:32.686: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[5] for the tag[6]
*Mar 1 23:38:32.686: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x81DC44B4], tdObject[0x81DD6194]
*Mar 1 23:38:32.686: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[0] for the tag[5]
*Mar 1 23:38:32.690: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x81DC44B4], tdObject[0x81DD61F4]
*Mar 1 23:38:32.690: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[6] for the tag[19]
*Mar 1 23:38:32.690: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x81DC44B4], tdObject[0x82435728]
*Mar 1 23:38:32.690: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[0] for the tag[22]
*Mar 1 23:38:32.690: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x81DC44B4], tdObject[0x81DD62C4]
*Mar 1 23:38:32.690: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager:
*Mar 1 23:38:32.690: ccTDUtilDumpAllElemInProfileTab: profileTable[0x81DC44B4], numBuckets[11], numEntries[4]
*Mar 1 23:38:32.690: Bucket { 0 } ------>0x81DD61F4[0x81DD62C4,t-5,l-44,d-0x81DD6214,m-4,u-85112,g-FACE0FFF]------>0x81DD62C4[0x0,t-22,l-12,d-0x81DD62E4,m-4,u-85112,g-FACE0FFF]
*Mar 1 23:38:32.690: Bucket { 5 } ------>0x81DD6194[0x0,t-6,l-16,d-0x81DD61B4,m-2,u-85112,g-FACE0FFF]
*Mar 1 23:38:32.690: Bucket { 6 } ------>0x82435728[0x0,t-19,m-2,g-FACE0FFF 0x81DD6270,i-0<t-19,l-4,d-0x81DD6290,m-2,u-85112,g-FACE0FFF> ]
*Mar 1 23:38:32.690: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x81DC2E90]
*Mar 1 23:38:32.694: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: remote IP is 172.17.15.2
*Mar 1 23:38:32.694: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: hwidb is Serial0/0
*Mar 1 23:38:32.694: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: create entry in list: 1
*Mar 1 23:38:32.694: //-1/xxxxxxxxxxxx/CCAPI/cc_can_gateway: Call legs: In=1, Out=1
*Mar 1 23:38:32.694: //-1/xxxxxxxxxxxx/CCAPI/cc_can_gateway: Call legs: In=3, Out=3
*Mar 1 23:38:32.694: //-1/xxxxxxxxxxxx/CCAPI/cc_can_gateway: Call legs: In=1, Out=3
*Mar 1 23:38:32.694: //-1/xxxxxxxxxxxx/CCAPI/cc_can_gateway: Call legs: In=3, Out=1
*Mar 1 23:38:32.698: //-1/xxxxxxxxxxxx/CCAPI/cc_process_call_setup_ind: (event=0x825A996C)
*Mar 1 23:38:32.698: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup: matching parameters - called# [6000], calling# [7099], consultid []
*Mar 1 23:38:32.698: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search: Searching for node with called# [6000], calling# [7099], consultid []
*Mar 1 23:38:32.698: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup: No matching node
*Mar 1 23:38:32.698: //59/D21987098077/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 59 with tag 98 to app "DEFAULT"
*Mar 1 23:38:32.698: //59/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(24=CC_EV_CALL_SETUP_IND), cid(59), disp(0)
*Mar 1 23:38:32.698: //59/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(59), disp(0)
*Mar 1 23:38:32.698: //59/xxxxxxxxxxxx/SSAPP:-1:-1/ssaCallSetupInd:
*Mar 1 23:38:32.698: //59/xxxxxxxxxxxx/CCAPI/ccCallSetContext: (callID=0x3B, context=0x81DC21E4)
*Mar 1 23:38:32.698: //59/D21987098077/SSAPP:98:-1/ssaCallSetupInd: cid(59), st(SSA_CS_MAPPING),oldst(0), ev(24)ev->e.evCallSetupInd.nCallInfo.finalDestFlag = 1
*Mar 1 23:38:32.702: //59/D21987098077/SSAPP:98:-1/ssaCallSetupInd: src route label=, tgt route label= tg_label_flag 0x0
*Mar 1 23:38:32.702: //59/D21987098077/SSAPP:98:-1/ssaCallSetupInd: finalDest cllng(7099), clled(6000) tgt_route_label()tg_label_flag 0x0
*Mar 1 23:38:32.702: //59/D21987098077/SSAPP:98:-1/ssaCallSetupInd: cid(59), st(SSA_CS_CALL_SETTING),oldst(0), ev(24)dpMatchPeersMoreArg result= 0
*Mar 1 23:38:32.702: //59/D21987098077/SSAPP:98:-1/ssaDebugPeers: ssaSetupPeer cid(59) peer list: tag(97) called number (6000)
*Mar 1 23:38:32.702: //59/D21987098077/SSAPP:98:-1/ssaSetupPeer: dialpeer tags in rotary= 97
*Mar 1 23:38:32.702: //59/D21987098077/SSAPP:98:-1/ssaSetupPeer: cid(59), destPat(6000), matched(0), prefix(), peer(81DDF044), peer->encapType (2)
*Mar 1 23:38:32.702: //-1/xxxxxxxxxxxx/CCAPI/cc_can_gateway: Call legs: In=1, Out=1
*Mar 1 23:38:32.702: //59/D21987098077/SSAPP:98:-1/ssaSetupPeer: cid(59), can't gateway with peer tag(97))
*Mar 1 23:38:32.702: //59/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[59], tagID[24], instID[-1]
Silver
Re: Incoming and outgoing VOIP Dial peer
On RL02 change the destination pattern from . to either .... or .T
destination-pattern ....
A . matches a single dialed digit, in which case if you dial 6000, there is no match and hence reorder tone.
Silver
Just point the voip dial-peer on RL02 to the callmanager instead of the next hop router
codec g711ulaw
no vad
Thanks, this worked
I also had to setup another gateway in my CallManager to point to RL02. I thought you had to point everything to one gateway and route to your remote sites from there.
Cheers Ryan
182
