Incoming Call From PSTN first 2-3 sec with no audio
CCM Cluster 4.1.3 sr2 with 5 remote branch PSTN connected using H323 Gateway.
Many times ISDN incoming calls terminated into an H323 Voice Gateway located into one of 5 remote site are silent for 2-3 seconds after the connect status. The calling can hear the other side that repaat (hello, hello) for 3 second, after that the audio works fine
Silver
Re: Incoming Call From PSTN first 2-3 sec with no audio
Try entering this command on the gateway. This would enable the cut-through of voice in both directions when RTP channel is open.
voice rtp send-recv
Anup
I always use this command
See if fast start is enabled inbound in callmanager.
The parameter name in Callmanager is:
H323FastStartInbound <
Look under Service Parameters > Call Manager >
Hope this helps
I thought FastStart was Device > Gateway > Incoming > Inbound FastStart...in 4.1(3)SR2..
I have the same problem but using CM 3.3(3) with 3 cluster, the solution is the same one?
160
