10-25-2006 05:24 PM - edited 03-13-2019 03:32 PM
Hello Guys,
I have an issue with the incoming calls. We I dial the 10 digitss number using my Cell phone, it doesn't go through. I receive a message stating "the call can't go through". But we can call from inside to outside and within the company.
Also when I try to add a dial-peer, an error message stating "Could not add peer" appears.
Could you please help me out?
The gateway is a 3640 H.323.
This is the output of the debug isdn q931. I am dialing 617-717-7982.
Oct 26 2006 02:23:56.129: ISDN Se1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x00E1
Bearer Capability i = 0x8090
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE1808386
Preferred, Interface 0, Channel 6
Net Specific Fac i = 0x00E7
Calling Party Number i = 0x2181, '6178692545'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '7982'
Oct 26 2006 02:23:56.169: ISDN Se1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x80E1
Channel ID i = 0xA98386
Exclusive, Channel 6
Oct 26 2006 02:23:56.253: ISDN Se1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x80E1
Cause i = 0x80A6 - Network out of order
Oct 26 2006 02:23:56.301: ISDN Se1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x00E1
Oct 26 2006 02:23:56.309: ISDN Se1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x80E1
10-25-2006 06:37 PM
10-25-2006 06:57 PM
From your output it would seem that your striping digits off.
If your dialing 617-717-7982, but the ISDN is presented with only the last 4 digits, "Called Party Number i = 0xA1, '7982'"
Can you provide the configuration?
10-25-2006 07:13 PM
10-25-2006 08:30 PM
Sorry, I miss read the initial problem, I thought that you where having problems without bound calls.
I can see from the configuration that there are two matching dial-peers, 7100 and 7200.
I've noticed that the interface F0/0 is missing the command 'h323-gateway voip interface'
The error is in the debug is 'Disconnect Cause=38' this is typically casued by connection issues.
The gateway is not able to make a TCP connection to the CallManager. In the debugs see the gateway trying dial peer 7100 then dial peer 7200. This indicates to me the GW is not able to make a TCP connection to the CCM.
How has the gateway been setup in CallManager, DNS name or IP Address, make sure that Callmanager can resolve the gateway and ping etc.
10-25-2006 08:44 PM
Thanks for the reply,
Please note that we're able to make outbound calls for any number. 4 digits dialing working fine as well.
May be the h323-gatway command was missing in the config that I posted but I do have that command under the F0/0 Interface. Here's the config for the F0/0 Interface:
interface FastEthernet0/0
ip address 172.16.XXX.1 255.255.255.0
ip route-cache flow
speed 100
full-duplex
h323-gateway voip bind srcaddr 172.16.XXX.1
I See the GW is registered with CCM. As I said the only issue is that I can't receive any calls comming from PSTN network.
10-25-2006 08:55 PM
I've always used the addtional command "h323-gateway voip interface"
But as you say you can make outbound calls.
Have you tried using the hidden command 'csim start
Sorry I can't be anymore help.
10-25-2006 09:14 PM
I am in desprate need of help for this issue, can someone please help?
10-26-2006 02:42 AM
sounds like possibly a naming / IP address reference issue with the CallManager and H.323 GW. (I am assuming this is CCM from your session target...) I would try deleting the H.323 entry for this gateway and re-adding it, or, better yet, just Stop and Start CCM service, if you can.....
10-26-2006 04:22 AM
My question is why are we able to make outbound call if the session-targat address is wrong. Please consider the following two Dial-peer. For a call coming in from PSTN, which Dial-peer is going to be used? Accroding to me the Dial-peer voice 1001 will be used because the call is coming from PSTN therefore it going to use the PRI. Am I right?
dial-peer voice 7000 voip
preference 1
destination-pattern 7577
session target ipv4:172.16.165.10
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1001 pots
preference 1
destination-pattern [2-9].........
direct-inward-dial
port 1/0:23
forward-digits all
10-27-2006 05:36 AM
Could someone please respond to this posting?
10-28-2006 03:22 PM
Nobody can help?
11-01-2006 12:16 PM
Outbound calls use the dial-peer pots and incoming calls use the dial-peer voip. Thats why you can make outboud calls even the CCM addres is wrong..
