Incoming call not working
Hello Guys,
I have an issue with the incoming calls. We I dial the 10 digitss number using my Cell phone, it doesn't go through. I receive a message stating "the call can't go through". But we can call from inside to outside and within the company.
Also when I try to add a dial-peer, an error message stating "Could not add peer" appears.
Could you please help me out?
The gateway is a 3640 H.323.
This is the output of the debug isdn q931. I am dialing 617-717-7982.
Oct 26 2006 02:23:56.129: ISDN Se1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x00E1
Bearer Capability i = 0x8090
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE1808386
Preferred, Interface 0, Channel 6
Net Specific Fac i = 0x00E7
Calling Party Number i = 0x2181, '6178692545'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '7982'
Oct 26 2006 02:23:56.169: ISDN Se1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x80E1
Channel ID i = 0xA98386
Exclusive, Channel 6
Oct 26 2006 02:23:56.253: ISDN Se1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x80E1
Cause i = 0x80A6 - Network out of order
Oct 26 2006 02:23:56.301: ISDN Se1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x00E1
Oct 26 2006 02:23:56.309: ISDN Se1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x80E1
Re: Incoming call not working
The output of ccapi inout is in attach.
From your output it would seem that your striping digits off.
If your dialing 617-717-7982, but the ISDN is presented with only the last 4 digits, "Called Party Number i = 0xA1, '7982'"
Can you provide the configuration?
Thanks for your help,
Attached is the config
Thanks again,
Sorry, I miss read the initial problem, I thought that you where having problems without bound calls.
I can see from the configuration that there are two matching dial-peers, 7100 and 7200.
I've noticed that the interface F0/0 is missing the command 'h323-gateway voip interface'
The error is in the debug is 'Disconnect Cause=38' this is typically casued by connection issues.
The gateway is not able to make a TCP connection to the CallManager. In the debugs see the gateway trying dial peer 7100 then dial peer 7200. This indicates to me the GW is not able to make a TCP connection to the CCM.
How has the gateway been setup in CallManager, DNS name or IP Address, make sure that Callmanager can resolve the gateway and ping etc.
Thanks for the reply,
Please note that we're able to make outbound calls for any number. 4 digits dialing working fine as well.
May be the h323-gatway command was missing in the config that I posted but I do have that command under the F0/0 Interface. Here's the config for the F0/0 Interface:
interface FastEthernet0/0
ip address 172.16.XXX.1 255.255.255.0
ip route-cache flow
speed 100
full-duplex
h323-gateway voip bind srcaddr 172.16.XXX.1
I See the GW is registered with CCM. As I said the only issue is that I can't receive any calls comming from PSTN network.
I've always used the addtional command "h323-gateway voip interface"
But as you say you can make outbound calls.
Have you tried using the hidden command 'csim start ' to see if the gateway can make the call?
Sorry I can't be anymore help.
I am in desprate need of help for this issue, can someone please help?
sounds like possibly a naming / IP address reference issue with the CallManager and H.323 GW. (I am assuming this is CCM from your session target...) I would try deleting the H.323 entry for this gateway and re-adding it, or, better yet, just Stop and Start CCM service, if you can.....
My question is why are we able to make outbound call if the session-targat address is wrong. Please consider the following two Dial-peer. For a call coming in from PSTN, which Dial-peer is going to be used? Accroding to me the Dial-peer voice 1001 will be used because the call is coming from PSTN therefore it going to use the PRI. Am I right?
dial-peer voice 7000 voip
preference 1
destination-pattern 7577
session target ipv4:172.16.165.10
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1001 pots
preference 1
destination-pattern [2-9].........
direct-inward-dial
port 1/0:23
forward-digits all
Could someone please respond to this posting?
Nobody can help?
Outbound calls use the dial-peer pots and incoming calls use the dial-peer voip. Thats why you can make outboud calls even the CCM addres is wrong..
415
