Community Member
Incoming call Rings all phones
I have small CCM deployment with MGCP gateway, 4 FXO ports and 6 phones. How would would I configuure Call Manager to ring all phones for each incoming call (like a key system)?
A number of the phones are 7910G (single line) and each phone has a unique extension.
How would you configure call manager to ring all
Re: Incoming call Rings all phones
I would configure under Attendant DN in the MGCP FXO port configuration the DN of a Hunt Pilot, then configure a Hunt List and a Line Group that uses Broadcast algorithm (CCM 4.X)
If early version configure a shared line.
Just to clarify on this, If I had 4 FXO lines in the router, should i have the the pstn company or LEC configure the (4) analogs in a hunt group?
I have a customer trying to figure out how to have DID's with analogs. I was thinking it might work. If I had the LEC configure (2)analogs in a hunt group, plug them into the router FXO card, can I configure the MGCP gateway and phone to respond to this?
Or I am fishing in the wrong creek? Just use it as one main number and have the attendant pick up and route to the extension it needs?
