Silver
Incoming call routing with CME
I am trying to set up a fairly unusual small office setup, and am hoping someone can help me figure out which of the features I need are possible. I am pretty sure some of them are not.
The office has a single standard phone line (1FB) with Caller-ID. The router is a 2621XM 12.3(14)T7 running CME 3.3. The site has 1 analog phone, 1 7960, and 1 fax machine, and the router has a 2fxo and 2fxs wic.
The features I would like to get working:
- I would like inbound calls to ring both the 7960 and the analog phone automatically. Right now I can have it ring one or the other, but not both.
- I would like to be able to switch between the analog and 7960 phones while on a call (this one may not be possible)
- I would like incoming calls to ring the second FXS line at the same time, so that I can plug in the fax when I want to receive a fax.
Bonus points if anyone knows if it is possible to route inbound calls by calling-party ID. If I could route certain numbers to a different extension or fxs port, that would be great for known inbound FAX numbers.
Eric
Re: Incoming call routing with CME
Create a shared line between analog phone and an ip phone.
ephone-dn 1 dual-line
no huntstop
number 5060
ephone 1
button 1:1
mac-address <>
dial-peer voice 20 pots
destination-pattern 5060
port 0/0 --- fxs port 1 where analog phone is plugged in.
dial-peer voice 21 pots
connection plar opx 5060
port 1/1 -- fxo port where telco pots line is plugged in
Not sure if item 2 and 3 can be done with just one pots line.
Silver
Thanks for the reply. I don't have an option under pots dial peer for connection, so I can't do exactly that. The "no huntstop" seems to be what I was missing, but it still doesn't work. Here's what I have so far:
voice-port 1/0/0
timing hookflash-out 50
connection plar opx 100
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
dial-peer voice 1 pots
destination-pattern 9T
!fxo
port 1/0/0
dial-peer voice 3 pots
destination-pattern 100
!fxs
port 1/1/0
number 100
call-forward busy 101
no huntstop
ephone 1
after-hour exempt
mac-address xxxx.xxxx.xxxx
type 7960
button 1:1 2:2 3s3 4s4
Am I on the right track?
I also didn't know about plar opx. That may be a partial solution. I can have the analog phone plugged into the wall as well, and with plar opx it will ring the 7960 and analog phone. Then if I pick up on the 7960, I can pick up the analog to join the conversation. I just couldn't pick up the 7960 to join a call answered by the analog.
Off to test a bit. Let me know if you see any reason the fxs still wouldn't ring.
-Eric
I apologize for putting you in the wrong track. When you create an ephone-dn, in essence its creating a virtual dial-peer. This dial-peer and the dial-peer for your analog phone will have the same preference, so the router will randomly select one of the dial-peers and ring that phone. So each time you call, you may get one of the phones to ring and not both.
To create a shared line between the ephone-dn and the analog phone, you will have to use a sccp device such as ATA 186 and plug the analog phone to the ATA. Since ATA and 7960 talks skinny to the router, both can share the same ephone-dn 1 (number 100). When you call inbound, both should ring at the same time.
Sankar
PS: Please remember to rate posts!
Silver
Ok, if that is the only option I'll have to go with the phone plugged into the wall, and the router using plar opx.
One last bit, do you know if it's possible for caller-id to work on my 7960? It isn't being passed to it right now.
-Eric
Silver
I will answer my own question here. It looks like the wic-2fxo doesn't support callerid. I'll have to get by without it for now.
Eric,
Have you already tried,
voice-port 0/0
caller-id enable
Also check this link
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a00800a9a49.shtml
Make sure you have callerid service available from your telco. (usually an additional cost).
Sankar
PS: please remember to rate posts!
Silver
Yeah, as I mentioned, I found out it is not supported on the wic-2fxo. My fxs offers the option, but the fxo doesn't.
Eric
Eric,
You are right. You need a min of Vic-2fxo-m1 or better to support caller id.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b53c7.shtml
445
