Incoming calls and SRST
We've set up SRST on the router of a remote site. Router is a 3825 and the CallManager is 4.1.2. When SRST kicks in, users can make outbound calls, but inbound calls won't go through. Part of the config is as follows:
call-manager-fallback
secondary-dialtone 9
max-conferences 4
transfer-system full-consult
limit-dn 7940 2
limit-dn 7960 4
timeouts interdigit 7
timeouts ringing 30
ip source-address 10.1.1.1 port 2000
max-ephones 50
max-dn 100
system message primary Operating in SRST Mode
system message secondary SRST
voicemail 5400
moh music-on-hold.au
Any idea?
Re: Incoming calls and SRST
You need to define the E.164 telephone prefix using dialplan-pattern command.
dialplan-pattern 1 295551... extension-length 4
Alternatively use num-exp in global config mode
num-exp 295551... 1...
-PMK
Hi p-kitaka
If you have a 4 digit extension plan and you telco are only sending you 4 digits, do you still need this command?
248
