Community Member
incoming calls get dropped
Hi Experts
I am having problem with my incoming calls.I am running CME 4.1 in 2821 router.The router has 4 port vic slot,4 analog lines are configured in this port.My incoming calls it gets dropped after 1 ring.Actually it should go to the CUE AA.
Suggest me if any changes needed in my configuration
voice-port 0/3/0
connection plar 5004
caller-id enable
voice-port 0/3/1
connection plar opx 401
caller-id enable
voice-port 0/3/2
caller-id enable
voice-port 0/3/3
caller-id enable
Please give your feedback about this problem
Hall of Fame Super Gold
Re: incoming calls get dropped
Can you call 401 or 5004, whatever the AA number actually is, from any phone ?
Community Member
yes I can call my AA pilot number 5004.internally it is working fine.
My configuration is below
voice-port 0/3/0
cptone AE
caller-id enable
voice-port 0/3/1
connection plar opx 5004
caller-id enable
voice-port 0/3/2
caller-id enable
voice-port 0/3/3
caller-id enable
dial-peer voice 50 voip
dtmf-relay h245-alphanumeric
dial-peer voice 5004 voip
description "autoattendant"
destination-pattern 5004
session protocol sipv2
session target ipv4:192.168.11.2
dtmf-relay sip-notify
codec g711ulaw
no vad
ephone-dn 150 dual-line
number 400
trunk 1 monitor-port 0/3/0
ephone-dn 151 dual-line
--More-- number 401
trunk 1 monitor-port 0/3/1
ephone-dn 152 dual-line
number 402
trunk 1 monitor-port 0/3/2
ephone-dn 153 dual-line
number 403
trunk 1 monitor-port 0/3/3
operator ephone-dn and ephone configuration
ephone-dn 22 dual-line
number 222
label 222
ephone 29
video
mac-address 001B.D508.67C6
type 7931
button 1:22 2:150 3:151 4:152
button 5:153
I hope the above configuration will help you to give solution for my problem
Please advice me
take "debug ccsip message" with "term mon" then make an incoming call to AA from outside.
Community Member
I did not get any debug output for first time when i tried .it was because that default incoming call was going to port 0/3/1 and operator was no geting cals coming to that port .after shuting down that interface only i got debug output.I cannot understand what is problem with port 0/3/1.
output attached.it is going to AA when cals come to other ports.
try removing "opx" from plar under 0/3/1.
Please rate post if it helps!
Community Member
i tried by removing opx .still the cals coming through that particular port is getting dropped (not able to to answer).The outgoing calls are also not going through that particular port.Following is my dial peer config
dial-peer voice 1 pots
destination-pattern 9T
port 0/3/0
dial-peer voice 2 pots
destination-pattern 9.[1-9]T
port 0/3/0
dial-peer voice 4 pots
port 0/3/1
dial-peer voice 5 pots
corlist outgoing call-domestic
description ** FXO pots dial-peer **
port 0/3/1
dial-peer voice 7 pots
corlist outgoing call-international
port 0/3/2
dial-peer voice 8 pots
port 0/3/2
dial-peer voice 10 pots
port 0/3/3
dial-peer voice 11 pots
port 0/3/3
dial-peer voice 3 pots
destination-pattern 9[1-9]T
port 0/3/0
dial-peer voice 6 pots
port 0/3/1
dial-peer voice 9 pots
port 0/3/2
dial-peer voice 12 pots
port 0/3/3problem with this port.
please help me to troubleshoot my problem
Hi, does the line work if you connect a phone to it ?
Note, you should use trunk-group to reduce the number of DPs. you have.
Community Member
There is no dial tone when I connect phone.I have told telecom people to check the line.Is there any way to check the physical line problem using any of the show commands in router.I have no idea about how to create trunk group.please help me to create trunk group.
no dialtone = bad line, have it repaired.
To configure trunkgrup, define trunk-gruop with a name of yourlikeing under each voice-port. Then use a singe Dp that references that instead of port.
As an appreciation to those providing answers, please rate useful posts with the scrollbox below!
200
