Incoming Dial-peer
I have a SIP trunk set up and can make outgoing calls fine. However, at the moment, i'm having a little trouble getting the incoming calls to be recieved on my ephone-dn.
When an incoming call is recieved I get the following from "debug ccsip all"
The Call Setup Information is:
Call Control Block (CCB) : 0x4838BFD4
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : +4418338xxxxx
Called Number : 4418336xxxxx
Source IP Address (Sig ): 83.x.x.x
Destn SIP Req Addr:Port : 87.x.x.x:5060
Destn SIP Resp Addr:Port : 87.x.x.x:5060
Destination Name : 87.x.x.x
Aug 25 08:24:38.529: //2100/FB9CA81483B9/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : g711ulaw
Negotiated Codec Bytes : 160
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0
Source IP Address (Media): 83.x.x.x
Source IP Port (Media): 18736
Destn IP Address (Media): 87.x.x.x
Destn IP Port (Media): 12272
Orig Destn IP Address:Port (Media): 0.0.0.0:0
I believe my problem lies with me incorrectly setting up my dial-peer. This is what i currently have.
dial-peer voice 9999 voip
description Incoming call via SIP
translate-outgoing called 3
destination-pattern 4418336xxxxx
translation-rule 3
Rule 0 ^4418336xxxxx 2000
2000 is my extension on CME4.0 and i've x'd up IPs and phone numbers for privacy.
I would have thought that translation-rule would replace the called number with my extension, which would in turn cause my extension to ring. No such luck though.
I can get the call to be put through to a normal phone via a pots dial-peer with the following dial-peer
dial-peer voice 9999 pots
port 0/1/1
Re: Incoming Dial-peer
If i give an ephone-dn a number of "4418336xxxxx" the call comes through, so i'm fairly certain its a translation rule problem. I just cant see where it's going wrong.
Try doing a "debug voice dialpeer" or "debug dialpeer" to see which inbound dial-peer you are hitting.
You also might want to try a translation profile, and translate incoming called. Similar to:
voice translation-rule 1
rule 1 /^4441833612345/ /2000/
voice translation-profile test
translate called 1
dial-peer voice 100 voip
incoming called-number .
translation-profile incoming test
Still pulling my hair out with this. I have tried your suggestion with the following setup:
voice translation-rule 10
rule 1 /^441833612345/ /2000/
voice translation-profile incSIP
translate called 10
dial-peer voice 1 voip
translation-profile incoming incSIP
Then with "debug voice dialpeer" activated, I get the following.
Aug 25 14:29:25.215: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=441833612345, Called Number=441833600026, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=441833612345
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Aug 25 14:29:25.215: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
Aug 25 14:29:25.219: //-1/F1237AF8804E/DPM/dpAssociateIncomingPeerCore:
Calling Number=+441833912345, Called Number=441833600026, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
Aug 25 14:29:27.663: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 25 14:29:27.667: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 25 14:29:27.667: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
Aug 25 14:29:27.667: //-1/F29902FC8050/DPM/dpAssociateIncomingPeerCore:
509
