Community Member
Inconvenient dial-in on Voice over Frame Relay
Dear Coleagues
I have two 1750 Cisco routers conected via a 64 Kb with 32 CIR frame relay link.
Both 1750 has one E/M plug in with two channels each.
I have a 20 KHz reserved Bandwidth for the voice communication and 12 KHz for data link.
In this enviroment I´m experiencing the following inconvenient: In some cases when I dial from both ends to diferents extensions I connect to other one.
It don´t happens every times, It only happens some times for example in a 20% cases for some extensions and until a 40% for other.
DIALING procedure: When I press a button on the terminal It dials automatically the local 1750 line and the remote 1750 line, and after I dial the extension number manually.
So that I want to know if exist some debug command that can show me the dialed number, in both 1750, in order to isolate if exist the faulting point.
Additionally if Somebody has any similar experience and found a solution I´ll be very gratefull from now.
Thanks Hugo COLOMBO
Re: Inconvenient dial-in on Voice over Frame Relay
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit and to open a case with one of our TAC engineers, visit
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
