Info on how to build a basic Ip Telephony System
Hi my friends,
I would like to set up an IP Telephony test environment.Just need a quick overview on how would I go by setting one up.
Basically I need some docs about the hardware and how to configure it.
Thank you in advance.
Re: Info on how to build a basic Ip Telephony System
I'm not quite sure where you should start but the following sites helped me. I was pretty green to VoIP network planning & configuration until about 2 months ago. The following pages should help get you up and running your own straight forward VoIP network. Good luck:
Start up donfiguration
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_serv/as5400/hw_inst/53_54qsg.htm#xtocid29
Vo-IP Configuration
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_serv/as5350/sw_conf/53swcg/54voice.htm#xtocid0
Dial-Peer configuration
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_serv/as5400/sw_conf/ios_121/puldt662.htm#xtocid279040
Dear Mr. KEVIN WHITE
SR SUPPORT ENGINEER, PEREGRINE SYSTEMS
In order to planning an IP Telephony Network You can follow this link.
http://www.cisco.com/univercd/cc/td/doc/product/voice/ip_tele/solution/3_planni.pdf
ANd another for to get informationa related to Voice Over IP directly on the Cisco Main Page search window.
Another one if You are using a Frame Relay link You can employ Voice over Frame Relay wich has a very good behavior, mainly because you can select different MTU for the voice paket and for the data packets.
Your sincerously Hugo COLOMBO
hugo@hch.com.ar
If you are a Cisco Partner and have access to the PEC you can access some VOD sessions on basic VOIP deployments/design. I also took a KnowledgeNet online lab that allowed me to configure and play with a complete Cisco VOIP environment, pretty cool stuff.
Check out the Partner E-Learning Connection
107
