Community Member
Initial delay in conversation
We are having a strange problem, sometimes there is a delay from when you pick up the receiver until you can talk to the person phoning. It takes about 3 seconds to bring up the timer on the phone from when you pick up the handset. After this period is over the conversation is normal without delay or interference.
We have multiple voice VLAN’s, it seems like calls from the same VLAN are fine, it is only calls from other VLANs or from outside.
I would be thankful for any suggestion on where to start looking to get this problem resolved.
Henk
Hall of Fame Super Silver
Re: Initial delay in conversation
What version of CCM do you have.
Is QoS configured in your Campus?
I had a similar issue some time ago on 3.3, which was fixed with a new phone firmware provided by TAC, it was a known issue. I would suggest opening a TAC case.
Chris
Community Member
Chris
Thank you for the reply
We running CCM 4.0 and yes QoS is enabled.
I will investigate the firmware and open a TAC case.
Thank you
Henk
Community Member
I had a similar issue, it turned out to be QOS related.
Community Member
If you don't mind what in QoS caused the problem ?
Community Member
As a note, I have resolved this problem. It was the CallManager and by restarting the server fixed the problem. Exact cause not know, but I suspect a memory leak.
Cheers
Henk
Community Member
Specifically lack of qos on a WAN link. The call setup (control traffic) was fine, but the rtp stream was delayed due to latency.
glad you problem is corrected.
143
