Silver
Inline Power problem on 4507 switch
I have a 4507 switch with 48 port inline power module. One port is giving me problem, fa7/13. The phone gets the power for sometime, and then the power goes off, then power on again. Between power transitions, I get the below error messages. Anybody seen it before. I also didnot find a CCO document on the debug ilpower command, anyone know of any link in CCO for that command.
The phones work in other ports, so phones are fine, cables have been checked and they are also fine.
DAY-SW-10-4507#debug ilpower ?
port ILPOWER port management
registries ILPOWER registries
scp ILPOWER SCP messages
DAY-SW-10-4507#debug ilpower reg
ILPOWER registries debugging is on
DAY-SW-10-4507#debug ilpower scp
ILPOWER SCP messages debugging is on
DAY-SW-10-4507#SH POWER INLINE fa7/13
Interface Admin Oper Power Device
(Watts)
Fa7/13 auto on 7.0 cisco phone device
13w6d: ilpower_pd_statechange( Fa7/13 ) pd_class: 0
13w6d: ilpower_powerchange( Fa7/13 ) power: 7000
13w6d: ilpower_pd_statechange( Fa7/13 ) pd_class: 2
13w6d: ilpower_powerchange( Fa7/13 ) power: 0
(Watts)
Fa7/13 auto off 0 unknown
Re: Inline Power problem on 4507 switch
Is this happening on all blades on your 4507? Can you take that phone that is having this problem to another blade in the switch and it works fine?
If its not occuring on any other blades and all of the phones work fine in every other port, perhaps you have a bad port. If you can go ahead and try another blade in place of the blade with the problem port. This will rule out hardware.
HTH,
Mike
If the new blade still holds the same problem then I would open a TAC case and give the engineer your situation. Also give them your 4507 IOS Version so you can have the Engineer do a DDTS-Google search to see if there are any matches to this situation.
Silver
It definitely looks like a hardware problem with that port. On the same blade, the phone works when connected to another port. However customer says that he had observed this problem on other 4507's and the problem got resolved by itself. So, this time he wants to troubleshoot further.
248
