You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
Installation advice required: UM 4.0.3 with Win2k active/active clustering
Current Exchange setup:
2 E2K servers(active/active) with 5 mail stores in each server.
2 smtp gateway(E2K),1 OWA gateway(E2K) and 1 E5.5 gateway acting as the frontend for email.
Anyone done a similiar setup before?
My intention is to make one of the E2K smtp gateway as the partner server for Unity, or should I target the partner server on the cluster itself.
Any pitfall that I should take note of?
Appreciate any comments and advice.
  • Other Collaboration Voice and Video Subjects
1 REPLY
Gold
Re: Installation advice required: UM 4.0.3 with Win2k active/act
Availably of the partner Exchange server is critical. If it goes offline nobody can check voicemail over the phone, etc. Therefore you should use a clustered Exchange server as the partner server as they are generally more available than non-clustered servers.
Keith
95
